allright i've been gonna install the passenger peg led's for a while now figured i'd go ahead and hook 'em up tonight so here goes
#1 gather materials
side snips
shrink wrap
soldering iron
led's
resistors
where i got my leds and resistors
http://cgi.ebay.com/50-PCs-UltraBri...66954QQcmdZViewItemQQ_trksidZp1713.m153.l1262
superglue
drill bit
clear silicone
solder
hobby knife (optional i used it to bend the leads on the leds)
9 volt battery (for testing led's)
dremel (i was right on top of a casting plug)
marker and paper (not shown)
#2 make a template and mark the locations and drill your holes, measure very carefully mine were still off a hair!!!!!
#3 insert LED's with the small lead towards you this is the ANODE or NEGATIVE lead!! place a drop of superglue on each one allow to dry
#4 i had a casting plug by one of my holes and had to dremel it away so the led would sit flush
#5 Bend LED leads over so that each one over laps the other
#6 solder the leads remember heat until the solder flows smoothly
#7 attach your resistors i used one on the anode and cathode
#8 insulate with appropriate size shrink wrap
#9 seal with clear silicone
#10 finished you can see the slightest error is very noticable
NOW GO INSTALL THEM !!!!
heres a vid of how they look
http://www.youtube.com/watch?v=fcv99DRBYs8
· 2 Fast 4 U
Hey Nitro... just wondering why you need resistors?
once i followed all the steps, how do I connect the LEDs to my turn signals? I will have the same thing as you - taillight with integrated turn signals. pics would be very helpful
