1 - 14 of 14 Posts
Happy go Lucky Guy
Sticky Throttle help!
Hey Guys,
My throttle stick a little when I allow it to reset all the way back ? (I tend to have a bumpy take off, but then I am a newbie)
Any ideas how I may be able to repair my sticky throttle situation ?
2006-2007 owners what rpm range do you usually shift for steady speed ?
Thanks Guys,
Draggin knee's
Normal cruising: i shift in between about 6-8000rpm
As for the sticking of the throttle: No... never had this issue. U should get that fix'd asap. Maybe some new grips might help
Happy go Lucky Guy
got it, i tend to shift around 4-5k, does that also include first gear ?
Thanks
(looks like I need to check my throttle problem as it is not smooth at all when it resets back.)
Draggin knee's
Thanks
Yea, pretty much. Im always shifting around the same spot unless im giving her hell. U can shift at ANY spot in your rpms and it will be safe. As long as ur pullin in the clutch an ur not going over the red line an letting it rev out the engine ur fine.
If your up at about 12-13000rpm+ an wanna power shift without the clutch its also pretty safe to do so. But ONLY at the higher rpm. Never do it under low rpm. And ALWAYS down shift with the clutch
Happy go Lucky Guy
Discussion Starter · #5 · (Edited)
very helpful advise, Thank you
Do you pull the clutch all the way in when your about to shift and downshift ?
Draggin knee's
Depends how tight u have your clutch set. Mines pretty loose so i only gotta pull it in half way for the clutch to disengage.
Draggin knee's
As long as its a smooth transition from gear to gear ur doing fine. Its basic riding really
Happy go Lucky Guy
oh okay, mine is in its stock configuration, any idea how I might go about repairing my throttle problem ? I read about lubing with WD40 etc..
Thanks for your feedback HBHarrison!
Draggin knee's
Anytime dude...
Lube your Throttle cable. Never done it myself but im pretty sure that would help.
Try this...http://www.protectall.com/cable_life.htm
Happy go Lucky Guy
Great, Ill give it a shot.
Thanks once again!
Just Burnin Time
You can shift without the clutch at any RPM and you can EASILY downshift without the clutch. I only use my clutch when i am simply cruising... Other than that, WOT and no clutch for me...
Hey Guy
^^^ i agree. I almost never use my clutch. only in first gear, and when coming to a stop.
To shift without the clutch, just apply a little pressure to the shifter and let off the throttle a little and it will shift. If you're cruising, you dont even really have to let off the throttle.
I usually shift around 4-5000 rpm on the street.
1 - 14 of 14 Posts
