1 - 20 of 21 Posts
So, my first tire change was this weekend (on the R6). I have a forward handle pit bull stand. I realized the stand cups for the spools cover the axle. Had to loosen off the stand, insert tire, then tighten off the stand. That's ridiculous. Anyone else have the issue? I suppose I can cut the cups, but then stability might be compromised.
Pit Bull is awesome, so this surprised me. Anyone have any other solutions?
"The Dude abides .. "
ya need to post a photo.. been using pit bull stand for 10 years and have no idea why you would have that issue.
Reads the rulez
Another positive reason to use the headlift stands over the forklift.
Which has exactly jack shit to do with the OP's problem at hand. :bowroll
My R6 loves me
Well, I feel a little better as I'm not the only one. :lmao
There is no easy solution, beyond what you already did, unless you want to either get a rear lift pit or new axle blocks w/ sliders.
The axle blocks are fairly common, I have r&g for example. Driven also makes a set that the STG was pimpin for some time as well.
Reads the rulez
Odd...I've never seen that problem.
Ask a Doc Super Mod!
Agree with Melka. Need pics. I suspect you may have it positioned wrong. Doing this for as long as I can remember and never seen you have to take bike off the stand to tighten anything.
in this case, ya just need to space that nut out some as you point out .. i don't know what brand of adjusters those are, but they are not stock, and are likely causing the problem the OP has. With stock axle adjuster blocks, there should not be a problem.
not sure if this will help, but i reverse my axle. I want the axle to push in on the brake side.
Now picture those pics w the stand directly in front of the axle. Stock chain and sprocket, only 1k on the bike. Didn't get home from work until late, I'll get a pick tonight.
Spoke to Pit Bull, and they'll take care of me. They always do; simply one of the best companies in MCs today. No reason to buy any other stands, ever, esp. the red direct copies, made in China.
Reads the rulez
Agree 100%!
nom nom nom nom nom nom
That's good to know. I'll have to shoot them an email. I love the forward handled rear stand, no issues if I wasn't changing a tire. I have a half dozen pitbull stands so I just used a rear handled one. I did have to adjust the plates up more on the forward handled one when I went to a 180/60 since the bar going under the tire didn't clear. It's nice to have adjustability and nice to know they stand behind their products.
1 - 20 of 21 Posts
