Can someone help me out and tell me what RPM range is the powerband. I have a 2007 R6. Thanks.
I can tell you right now, I have the same bike. Its between 10-14k, it gets pretty nasty in the lower gears, your front end will come up in 1st and 2nd.Can someone help me out and tell me what RPM range is the powerband. I have a 2007 R6. Thanks.
Do you even HAVE an R6? loli'd say thats way off, much higher past 10 and your gonna start going on the downhill half...starts somehwere around 6 i dont know where the actual peak is at.
:lmao. mine starts to get it at about 8-9k and its up hill from there to about 14.5k like was stated earlier.Do you even HAVE an R6? lol
:lmao :stupicDo you even HAVE an R6? lol
Mine pulls the front tires when i shift into 3rd.I can tell you right now, I have the same bike. Its between 10-14k, it gets pretty nasty in the lower gears, your front end will come up in 1st and 2nd.
:lmaoRichy,
When your absolutely sure the pistons are going to leap out of the engine, wait a little longer before you shift. If the tach drops below 8000, get off and push!! ;}
8 Ball
