501 - 518 of 518 Posts
Does anyone have a map for an 07 with a PCV, yoshi slip on, and an m4 mid pipe? Thanks.
Power commander website has a lot of maps to choose from. I have an akropovic header with mini gytr muffler, but I'm using the Yoshi map and bike runs good. Nothing will beat a custom dyno tune, but you can get close enough that it won't really matter.
Hi all
new member here.
Got A 09 r6
Just fitted SS manifold with cat delete with toce slip on, BMC race filter removing air restriction, and PCV. Bike seems to be running ok, but lost all low down response, im assuming lack of backpressure, anyone care to share a PCV map similar to my setup, been ringing around a few people to map the bike, but no answers so far.
would greatly appreciate any advice
thanks
Oz
Ow ,NuckenFuts
Hi all
new member here.
Got A 09 r6
thanks
Oz
What kind if Y pipe did you use ,and did you remove the honeycomb in the header? I would get with chiefsmokedawg on the forum, He can help work it out .I also highly recommend you have him flash you ECM.
Good luck.
Try and load the MJS map from Dynojet that map is rich and will make up for the loss of power you have down low. Remember all the mods you did will make it scream up top so the sacrifice is you lose a little low-end. Also as Nuges stated you could have Chief, SBU, TAFB, myself or anyone else who has the capability to flash the ECU to flash it for you. Flashing it will remove a lot of the factory restrictions and you can actually load the PCV map on the ECU so you won't need it anymore. Just a thought, but you should try the MJS map I think you'll be happy with it.
I have a mjs mid pipe with a toce slip on. pc5 running with auto tune. Was curious what map anybody else was using for a similar set up with a slip on with no baffles
I have a 2003 Yamaha r6 with jardine rt1 slip on pipe and k & n filter. Also pcIII power commander and need a map for it. Plan to get a dyno tune up soon but just wondering if anyone out there has the same set up and a custom map available ?? Living in Australia and would really appreciate any help from a fellow r6 rider. Much appreciated
I just picked up my 2005 R6 last week and I currently have a LeoVince SBK high mount, K&N air filter and PCV looking for a map. The one provided by PCV was either too lean and rich, I couldn't really tell. It definitely didn't smell right. Any help would be appreciated, please and thank you!
Im going to apologize in advance, i need 5 posts to see any attachments.
I have a 2006 r6 with stock filter and headers, an m4 cat delete y pipe, and a gytr gp slip on and a PCV
I was told by the guys at power commander to try the graves slip on and full exhaust maps and neither seems quite right.
1. Has anyone run a similar setup and have a map suggestion?
2. How do i know if i have the right map?
Thanks
I'm more than happy with PCV for my midpipe install, paid a bit more but more you can squeeze out of it as you grow as a rider and in technical/mechanical knowledge
I just bought a 2018 r6. Looking at the list of maps available from power commander for my bike, there’s something like 6 options?! I’m thinking of doing m4 midpipe with m4 street slayer slipon. I know nothing about this stuff but not sure what people are expected to do buying these newer model bikes with no maps currently available for them?
Is the auto tune addon something that can just be done once, create a map from it then just keep the pcv?
