1 - 12 of 12 Posts
This sounds like a stupid question. I just drained the oil and removed the crush washer from the bolt. The new one is about three times as thick as the old one. I know it is a crush washer, but it looks to thick. Does it matter? Just though I would ask, this wouldn't be the first time I got the wrong part from a dealership.
Thanks,
Todd
My R6 eats with me
It's most likely the right one, they are a fair bit thicker when new. As long as it fits properly diameter wise it should be all good. After you re-install the drain bolt and tighten it up properly, add new oil, clean it up, run the engine, and check for leaks.
I'm To Sexy For My Raven
thats how the other one looked when installed at the factory, your golden
1 - 12 of 12 Posts
