Could be a coil or a plug, definitely sounds like you lost a cylinder from what you say.
Sound clip,?
Could be a coil or a plug, definitely sounds like you lost a cylinder from what you say.I have a 2007 r6. Full pipe, bmc air filter, and power commander. I rode to the store about 30 min away. Stopped to get food at another location. Bike was running fine tell then. Started to ride home and noticed the exhaust sounded funny. As I pulled out of the place i almost stalled it. Not the usual throttle response. Second and third was bogging it still had power but not the typical pick up and go. As my roommate said as I was rolling up to my house sounded like a Subaru. I pulled off the gas tank and checked the air filter, which was fine. There seems to be an excess of gas in the throttle body right after the air filter. I haven't checked the spark plugs, but if one of them is fouled out, why would have it happened?
No problem, let us know what ya find. Good luck..Already have it apart. Checking the plugs. Someone else said that its probably the plug as well. Thanks
Does this mean you tested the resistance on the coils and got your answer on the coils are good or you just grounded the plug and saw spark?Touched them against metal they all sparked pretty evenly. Have not tried to do it with out the power commander. Probably my next step. Have the bike still torn apart to the spark plugs. Thanks
its possible to have a weak spark that can be seen by grounding the plug but isnt hot enough to spark the cylinder under pressure, i suggest finding a friend with an ohmmeter in your vicinity.grounded them and saw spark. Trying to avoid taking it somewhere and don't have the tools to test the resistance. Doing the power commander next after everything is together and than checking the fuel filter.
WOW!!!! Your description of what happened is exactly (almost scarily accurate) what happened to me. Exhaust sounded funny. No giddy-up. Sounded like a straight piped Suby. Based on my same circumstances Im pursuing the coils as well. Can you give some insight on getting them replaced? Im trying to avoid the shop and Id like to use this as a learning experience. I got my gas tank and airbox off and now i dont know what im looking for. I can even seem to find the coils! someone help! diagrams and pictures needed! THanks!Got the voltmeter. Primary resistance is 1.9 on all 4. Secondary 9.37, 9.37, 9.54, and 5.4. Think I found the problem. Should I replace all 4 of them? Spec is 1.61 on primary resistance. Thanks for everyones advice, input and time. R6 love!
Tip of advice, when reading through a thread you found while searching the forum... check the date of the last post before you comment.WOW!!!! Your description of what happened is exactly (almost scarily accurate) what happened to me. Exhaust sounded funny. No giddy-up. Sounded like a straight piped Suby. Based on my same circumstances Im pursuing the coils as well. Can you give some insight on getting them replaced? Im trying to avoid the shop and Id like to use this as a learning experience. I got my gas tank and airbox off and now i dont know what im looking for. I can even seem to find the coils! someone help! diagrams and pictures needed! THanks!
oh my bad. i didnt realize it was illeagal to post on a thread that was actually relevant to my issue. Im just trying to get some answers and keep my bike running.Tip of advice, when reading through a thread you found while searching the forum... check the date of the last post before you comment.
Welcome to the Forums.oke
Also i dont know if its any different for newerish bikes but the coils are a Coil over plug system. In other words, the black thing at the top of the spark plug caps where the wires plug in, thats your coil. One on each plug.
Not trying to knock you man just giving you some advice. People are like sharks hereoh my bad. i didnt realize it was illeagal to post on a thread that was actually relevant to my issue. Im just trying to get some answers and keep my bike running.
