1 - 7 of 7 Posts
This is a 2008 Yamaha R6. I took my bike to get some work done it by a local mechanic, I had the bike back for a few days, the next day I went to start the bike up, it was hard to start and when coming up to a stop it would shut off and be very hard to start, even when hot (I suspected valves were right immediately).. I pulled the top end off and to my suprise this is what I found. On the images, I even have issue getting the valve bucket removed.. Do I need a new cylinder? Or can this be repaired?? I also bought a 2007 Yamaha R6 last week and was wondering if the cylinder heads are same for years 2007 and 2008, I was wondering if I could just swap out the cylinder head and buy a new gasket.. Will this work or not?
Wow... never seen that before. Looks like it was starved of oil somehow. Ordinarily there's a healthy amount of lubrication up there. Shredded clutches have been known to clog the oil cooler on the front of the engine. Other than that, has to be low/no oil, severly overheated and/or severely neglected oil. Check the rest of the motor for evidence of overheat/starvation as well.
3rd-Gen parts should be the same. Should work; but seek a second opinion to be sure.
e
No other signs of oil starvation, so am suprised as well. The only thing I could say is that the cam bolts caps, two of the threading were gone, so am not sure if that would be the cause
Cam bolt bores barely hold to torque spec, particularly when there have been multiple valve-checks on an engine. People have been known to strip the bores.
Theory? - Cam bolts backed off enough to allow the gap and head to separate a little. Oil was then sheared-off in that gap, leading to starvation?
Holy, that´s pretty impressive..
If multiple valve-cheks were done, or the engine was just open alot, could changing the bolts "prevent" a thing, like this? or would it just be w.e?
1 - 7 of 7 Posts
