1 - 14 of 14 Posts
Hello! I have an '09 R6, it runs great other than a few issues that I don't often notice. My main concern at the moment is when I'm 1st-2nd gear, doing a hard acceleration about 10k rpms it's almost like it goes out of gear, nothing really "goes wrong" I just have to shift kind of early. I notice it less at higher gears, but I just wanted to see if anyone could put their 2 cents into the situation. I'll ride it again and look out for it to get a better idea of when exactly it happens. Maybe put less play in the throttle?? Thank you!
YZFR6... ooodles of HP
The rpm goes up without increase in ground speed as if you revved the engine? Then you most likely have clutch slip. Causes could be incorrect lever adjustment preventing full release of the clutch pack. Or worn/glazed friction and steel plates. What oil and how many miles on it? Have you the correct oil level? When was oil filter changed?
Discussion Starter #3
I adjusted my shorty levers for my clutch, I can ride at 12k rpms in 1st now, I loosened my clutch cable a little, I don’t really push it past that but I’ll try tonight, I gotta do an oil change I have 3 bottles of 15w-50 that I got from a friend, where I live it gets reallyyy hot todsy was 110, should I be using that oil or go thinner?
I use rotella t6 5-40. Good at 19F to 110F.today was 102F.
Discussion Starter #6
Sorry I missed half the question, 22k miles, last oil change/filter change was ~2,000 miles ago.
50 wt is probably ok. Never used it myself. But I changed my fana temp to come on so I only hit 220F sitting long periods at 2nd gear speeds.
It's been 105-115F here with about 4 days of thick smoke from a fire north of me and I'm running 195F plus at speed.
2 wheels > 4 wheels
While cruising, 200 ballpark makes sense (depending on ambient temp). But while sitting at a light, my thermostat never let me go past 220.
To the OP, you might wanna consider flushing your coolant if you're not sure when it was last done.
I understand this doesn't answer your question about gears. But hey, free internet advice!
Discussion Starter #12
I’ll be flushing the coolant in the next coming days, adjusting the clutch cable seemed to have helped. Thank you guys!
1 - 14 of 14 Posts
