1 - 7 of 7 Posts
I have a 09 r6 that isn’t starting. Bike has no codes, good spark, good compression, new fuel, and fuel pump primes. All it does crank but not start. Could it be a ecu problem or relay problem? Also all fuses are good.
Kind of Start with the most basic of things; that being your kill switch, your transmission neutral switch, your hand-clutch switch, your kickstand/sidestand switch. Read out these switches in diagnostic mode. (there may not be one for the hand clutch so will need to manually test using volt meter - a poor connection can develop there particularly when ridden in weather)
Have you taken a multimeter to all main engine component sensors and checked to make sure all wiring is fine? Lot's of things for a new engine man..... unless you're looking at it so idk if i'll be much help haha.
You could replace ALL relays? Do you know if the ECU was running fine on the last bike it was on?
Discussion Starter #7
I haven’t check anything yet with the multi meter and the guy said it came out of a running bike and it only has 7500 miles
1 - 7 of 7 Posts
