1 - 5 of 5 Posts
So when im in nuetral, should there be slack between 1st and 2nd gear? What i mean is in nuetral, if I put my foot on the shifter, should it be firm or not? It seems like before it was very crisp and now when i go from 1st to 2nd, i seem to be going to nuetral and not all the way to second. Seems like the distance between 1st, nuetral and 2nd has increased....anyone??
ps. when i had my oil change done the idiot forgot to tighten my shifter pedal back to stock and i had him fix it. Could it have fudged up somewhere between then and now..i put 400 miles on the bike since then
why would your shifter be loose if you're changin your oil???
But yeah, there is a little slack from neutral to first or second...its fine
To get the fairing off, you have to loosen the shifter to get to one of the bolts...so the guy forgot to attach it back and i rode off only to not be bale to put it into nuetral once in first....so i took it back and he fixed it. Ok so if the slack is fine then thats good i guess...
Ok, i guess i've never changed the oil on an 07 before. With my 03 i just take the fairing bolts off and there we are. But yeah, the slack is fine...
mine is the same way its normal
1 - 5 of 5 Posts
