1 - 2 of 2 Posts
i got a 07 r6 and the turn signals work completely fine but the right signal flickers when i give it gas. i will tap the back under the seat area of the bike and the signal flickers so some loose wire or fuse is causing it but i dont know which or how to diagnose it. i bought this bike used so no owners manual here is a attached video of my bike and the issue
https://www.youtube.com/watch?v=49JpkOfud18
I said biiiiiiiitch.....
I'm guessing your actual turn signal flickers along with the indicator?
Your best bet is to grab a wiring diagram and start checking for loose connections. Depending on what signals you have on, check for loose bulbs too. I'm not sure if there is a technique that would make this any easier. I would probably just start reseating all the connections one by one until it goes away.
1 - 2 of 2 Posts
