1 - 11 of 11 Posts
Hey guys, I have a 2007 r6s and i have an issue I need figured out as soon as possible. I went to start the bike the other day and all I heard was a buzzing under the seat and all the guages went retarded. So obviously I realized it was the starter relay. I purchased a new starter relay and its still buzzing!!!. Any help is super appreciated!!!!!!! Thanks in advance
That's what I was thinking also, but I put my volt meter up to it and it's reading just fine, unless my meter is faulty. I've even tried jumping the bike just to get it started and all it does is buzz
....Casper....
chase the wiring to the starter and check for 12v getting to the starter motor
plus figure out what is buzzing and get back to us.
also try rolling the bike off instead of using the starter let us know if it starts up
Similar thing happened to me last week. Went to start up the 6 after hibernation. It ran just fine last fall before I put it away. I did everything right (trickle charger etc..). Went to start it and everything looked fine (tach sweep, fuel pump) until I hit the start button. Everything died. From then on I'd get a buzz from the stater solenoid or a weak neutral light. Overall pretty intermittent behavior. The battery voltage was reading 12.8V without a load on it.
Leave your voltmeter leads connected when you press the start button and report back. If the voltage drops really low like less than 10V or lower it's your battery. I'd be willing to bet that's your problem.
Good luck
1 - 11 of 11 Posts
