Hi guys, I went to fire up my 2005 R6 this morning and she would start. The fuel pump no longer makes the priming noise when the ignition is switched on, and the engine management light flashes when the bike is turning over.
I've ran the diagnostics and d61 is giving "d61:30", which the haynes says is the lean angle sensor or the ecu. d8 in the diagnostics gives 0.8v which leads me to believe the sensor is fine?
Has anyone ever had a problem similar to this?
Cheers
