r6 will crank but not start
100 Views 3 Replies 2 Participants Last post by  8Ball
does the black/blue ignition switch wires not being plugged in be the problem?
1 - 4 of 4 Posts
That would be at least part of your problem, if not your whole issue
what is that wire for anyway? I know the brown/red one plugs in but what is the blue/black main purpose?
The blue/black wire goes from the ignition switch to the ECU. I assume it tells the ECU the switch is on and to fire the coils and injectors.
You need to get a service manual with a wiring diagram.
1 - 4 of 4 Posts
