Yes, about 97 octane.. Booster is pretty pointless.. All is USUALLY is, is Toluene, and some other crap..phantom menace said:so what is it good for then , ... only high combustion engines ??
so if i pu in 94 octan with the 104 octane boost it will only give me 97 octane ??
Yup, just a waste of money, but a "since of security"04areSix said:All the higher octane is used for is for higher compression engines. The higher the octane rating, the more it can be compressed without detonation. Chances are that your bike doesn't need anything more than premium from the pump.
over here in the uk you buy normal unleaded fuel at 93 octane for 83.9 pence a litre but they also do a super unleaded which is 95 octane which is about 90 pence a litre. and its what we run our 03 racer on. it won't do your bike any harm at all.....!krom said:I've heard that using octane booster over time can dry out your seals. I wouldn't use it too frequently anyways, because your computer is tuned for 91-93 octane and a higher octane would use a different fuel curve.
Do they use the same octane formula in Canada as in the US? I know Europe uses a different formula and 97 in Europe is equivalent to 91 in the States. I only ask because I've never seen 94 at the pump here.
this man speaks the truth! and he's not as slow as he says. he's just overly modest.RockyR6 said:I use VP Ultimate-4 race fuel, and it is actually LOWER octane than some pump gas... so racing gas isn't "just higher octane fuel". U-4 also happens to contain lead, as do many other race fuels.
Race fuels are formulated for different levels of volatility based upon the intended application. Some of them DO have higher octane ratings, but this is simply a byproduct of the development... not the end goal.
Running a higher octane fuel in an engine that doesn't need it actually HURTS the performance. The rule of thumb to follow is that you want to use the lowest octane you can run without pre-detonation, or "pinging".
Honestly, I don't see the neccessity to spend $10/gallon on fuel for your bike when you are riding on the street. It barely makes sense for slow racers like me.
