1 - 4 of 4 Posts
Hey, I have an 01 with a yoshi rs3 carbon.
I recently cut about 70mm off it.
it always popped on overrun and just holding and feathering the throttle. And now does it more .... Do I need to re jet?
What happens if I don't? Well it smooth it or under 4k? Its not bad, just prefers over 4k revs.
Any info, links would be much appreciated :)
First Gen FTW
I would rejet. It will run a lot better/smoother. And will reduce if not eliminate the backfiring popping.
I put a stage 3 in my 01 and it was like a new bike. have you changed the airfilter too? K&N or stock?
Not sure what it has, not long had it.
I'll pull it soon and check.
How do you know what kit? Description of mods?
Who does the most reasonably priced, half decent kits ?
First Gen FTW
DynoJet sells everything you need in a kit specific to your bike. Very easy to put in as well. It comes with step by step instructions as well as pix.
Usually run about 90-120. depending on what you get (Stage 1, Stage 2, or Stage 3)
Dont be intimidated. GL
1 - 4 of 4 Posts
