1 - 10 of 10 Posts
got some free genuine yamaha black aluminum spools from my bud at the stealership. are the yamaha spools compatible with the t-rex stand? thanks :dunce:
WATCHOUT...I'll be back
I am thinking it would. If it has the V shape cut out on the rear stand and the t-rex is made for spool, then your good to go. I have the pitbull rear stand and most of my friends use it when working on there bike at my house. So you should have no problem.
the yamaha spools look like this.
my t-rex stand looks like this.
just wondering if the bike is gonna slide around while workin on it? thanks
Yeah, that will work just fine. I use to have spools like that, but they were not yamaha brand and work great. Now I have woodcraft spool slider type and all I had to do is adjust the stand a little wider. And it looks like you can do the same with that t-rex. Just make sure to put a little blue loc-tite glue on you spool so it doesn't come loose itself.
yeah, they'll work great
Forum Moderator
What ever you do put a few drops of the blue loctite on them when you install them. I had the same spools and ended up loosing one at Deal's Gap.
you might have to "modify" that rear "fork" if you ever need to access your axle. i know me and gp1300r both have the yami spools, and the stand he has started with two equal sized "forks" that made getting the axle off/out impossible. it's an easy fix, though, should you run into this problem.
R is for respect!
+1 maybe you can post up the pic to show them.
just a grinder... and then a hand file (i didn't get around to touch-up paint by "photoshoot time" but you get the idea. :)
1 - 10 of 10 Posts
