1 - 7 of 7 Posts
Read Only
I need to replace my right foot beg and i noticed that its held by a rivet. Is this something I can fix easily at home or do I have to take it to the dealer? the dealer wants to charger me 42.50 just to put a new peg on.... seems kind of expensive. Also why doesn't yamaha just use a cotter pin on the right foot peg like the left?
You can drill out the rivet, put in a new peg and fasten it with a nut/bolt/loctite set up.
Or do what I did. But a used right rear set for cheap (prob ~$20). Disassemble your new rearset, the spring/peg assembly comes off as a whole. Remove your old rearset from your bike, and swap out the peg assemblies.
Might sound a bit goofy reading it, but it's really easy when you see it in person. Skip the dealer, buy a used rearset, swap the pegs, and save the spare parts for the future.
EDIT: It might help to know that the peg assembly and brake pedal are fastened to the rear set by a bolt on the inside of the set. Easy to unbolt when you remove the rearset, you can still leave it attached to the rear master cylinder.
Hakuna Matata, btches!
just drill the rivet out of the factory rear set
Step 1: Remove right rear set
Step 2: Remove allen bolt on the back of the rear set going through to the foot peg. Replacements from yamaha for like 40 bucks.
Step 3: Your done.
1 - 7 of 7 Posts
