1 - 4 of 4 Posts
First of all,
Big Thanks to Motomummy Corey and team on the exhaust and the pciii.
Installed:
K&N Filter
New spark plugs
Akrapovic Full Exhaust (Evo) Full Titanium
PCIII - Using the map from the PC website
Everything looks fine, but running quite rich.
Back fires most of the time whenever I let the gas off in second gear (high rpm)
I don't think there is a "good" tuner in town (in Hong Kong), so not confident to get it tuned by anybody...
Any solution/suggestions guys?
Thanks.
How hard is it to tune such a bike with a power commandar??
i can find a place that can get me to a dyno with air/fuel ratio showing...
how hard would it be to tune it with the PCIII?
also, what's the risk of actually losing more power?? or running lean??
R-Sex
there are some custom maps that are downloadable right off power comanders website, you could grab those and play with them a little bit. also there is a ton of gurus on here that can help lean out the a/f ratio. throw up some of your numbers/maps on here or in another post and see if you cant get some help.
1 - 4 of 4 Posts
