So here is the deal i have a 01 R6 that i bought and didnt run. All i had to do was ground the neutral switch to the body and it would start then when i would release the clutch in neutral with neutral switch light on all the time it would cut off. So i tried pulling the clutch sensor wires off and ting them togeather and it worked. basically becuase the clutch is saying it is in all the time and the neutral triped saying it is in neutral all the time. Well i fixed the neutral switch by cleaning it and taking out the washer that seperates the sensor from the case and the light was going off and on from netrual and to another gear and back. But when i started it up and put it into gear it cuts off weather or not i hook the clutch sensor back up or not. Then when i set it back up the way i had it everything was fine. I just want to get rid of that neutral light. any one have a answer why this is doing this?
