1 - 8 of 8 Posts
Keep in mind id never really heard of these tire sizes before seeing this thread. However I found some sizing info online for a set of Bridgestones. I compared that versus the standard sizes I’m used to seeing using 180/60-R17 vs 190/55-R17 Tire Comparison - Tire Size Calculator | Tacoma World
Assuming it’s all accurate, this is what I have.
For the rear, a Bridgestone (v01 or something) with the same 190/650 designation.
190/650-17
OD 649mm
TW 188.
180/55-17:
OD 630mm
TW 180mm
180/60-17:
OD 648mm ✅
TW 180mm
190/55-17:
OD 641mm
TW 190mm ✅
It’s kind of a mixture it seems. Personally I like the 180/60, it’s a taller profile and has good turn in responsiveness, also increased contact patch at the same lean angle versus 180/55.
On the front, again another Bridgestone 120/600 for comparison.
120/600-17:
OD 603mm
TW 117mm
120/60-17:
OD 576mm
TW 120mm ✅
120/70-17:
OD 600mm ✅
TW 120mm ✅
It seems to line up with the 120/70 size.
I hope this helps man. Again, this is based on specs I found online which could vary somewhat but hopefully puts you in the ballpark.
· Knee drags YOU!
From what I can tell, (Toyota) Tacoma World is referring to car (truck) tires on that site.
I don't think those measurements will translate directly to motorcycle tires.
Where did you find the measurements for the race-sized Bridgestones? I'd like to bookmark the reference.
Also, the other thing that I came across this morning while doing some research was tire profile.
How quickly the tire "slopes off" depends on tire height, width, and also rim width.
From what I gather, this will change how the bike tips into corners, contact patch while leaned over, and stability.
Man I didn’t even put that together on Tacoma, what an idiot. Good call out.
I got the tire info from here…190/650-17 V01 | Stickboy Racing
· Knee drags YOU!
You've given me the key metrics of overall diameter and tread width anyways.
Since these vary between brand and models, I'll have to get the specifics of each tire I'm looking at into a spreadsheet.
Will work on it tomorrow and report back with what I find!
· Knee drags YOU!
Font Circle Pattern Symmetry Number
Okay here is what I've worked out.
In regards to those slicks vs street tires:
Front has about the same height as a 120/70ZR17, but runs narrower by 2-5mm depending on brand and model.
Rear has the same height as a 190/55ZR17, but overall width closer to a 180/55ZR17.
Think I will be going with a 120/70ZR17 and 190/55ZR17 to maximize contact patch when cranked over.
(And because I can't get an RS-11 in a 180 rear).
1 - 8 of 8 Posts
