1 - 15 of 15 Posts
what is it , how does it differ from regular clutches ??
i know the new ninja comes stock with it....
I believe slipper clutches allow heavy downshifting without the fear of locking up the rear tire. I hear the uptake on slipper clutches is not as smooth though. I think they are designed to catch one way but the other way has ramps on the clutch and push the clutch pack apart when the tire runs slower than the engine. I know very little about slipper clutches and what I do know could be incorrect so hopefully someone can correct me or elabotrate.
just like the name implies, a slipper clutch allows for clutch slip when downshifting. You can drop 2-3 gears and the clutch will slip, instead of your rear tire chattering and slipping.
all i know is that i read about the new one they put on Rossi n Edward's M1 and it did some cray shit.....i can't remember what exactly it did but it sounded really cool....i want one....
ya preaty much the clutch will take the slip instead of the rear tire lock, for example if ur going about 45mph and u down shift into 2th and just drop the clutch ur rear wheel sorta locks for a split second until the gear box gets up to speed.
explanation here
http://www.hardracing.com/STM.htm
I would LOOOOVVVE to have this on my bike, but $1,000.00.....uuuuuh
my buddy put one on his Duc. 748...that thing was bad ass. His Aprillia Touono came with one too.
YOu can just dump it to first, let out the clutch, and it just raps out the motor and the clutch slips...but no wheel hope, tire slip.
It would be nice, but you guys could just not be pussies like all the rest of us and let it slip and slide around a bit on downshifts!!!
It sharpens the riders edge! :mrgreen:
I slide my rear end into corners on purpose so I wouldn't want one anyway.
I figure if I get used to it early, then it wont be a problem when it happens accidentally.
z31maniac said:
Or you could just learn to properly blip the throttle on downshifts instead of dropping $700-800 on something that does it for you.
Just a thought. :hammer
hmm, exactly the way I feel.
Not sure I want to go sideways into a corner, but, eh
1 - 15 of 15 Posts
