Decided to change oil a few weeks ago and overfilled, from that day no matter what i do the bike is not performing the same.
I was reading the wrong service manual and overfilled my bike, i noticed it when i took it for a spin and found out what i did and took out the excess oil, it acted a little better but far from perfect, so i talked to a friend and he told me to change the spark plugs, which i did and also clean out the intake manifold and change the air filter.
This makes it a little better with the sound and all but still not performing.
The bike seems like there is a lot of power but the rpm/speed is not climbing as it use to, i have to change the gears earlier than i am use to doing and there seems to be a lot of vibration.
I always use 93 gas so that is not the problem.
Also to note the day i did the oil change i change the orientation of my two bros slip on which was rubbing on the frame, i am not sure if this has anything to do with it as the bike seems like is short of either air or fuel and i am on the 3rd air filter.
I need some help in getting this bike back to par without having to spend a lot of money as my budget is tight.
Thanks.
Thanks.
