Hey guys, I just tried installing my speedmetal adjustable levers and ran into a problem. When the squeeze the front brake the lever doesnt return to the normal position and feels like the brakes are dragging.
I noticed the bolt that goes through the lever is very tight in the new lever. Also, there is a plastic circle on top of the lever that makes it fit very tightly, even without the nut and bolt being installed.
What do you guys recommend? I was thinking of trimming down the plastic circle could help. Also, is there any kind of lubricant that would help as well? Any help would be appreciated. Thanks.
You can see the rubber circle that I am talking about..
