1 - 20 of 20 Posts
Hello. Yes I have used the search option for sprockets but never got a direct answer. I also read dramas on sprockets.
I just need to know. Which sprocket have you used with no issues?
For a 520 conversion
Superlite RS7
Driven (steel)
Pitbull
Vortex
Thanks.
Official Noob Greeter
You actually searched and couldnt find an answer to this question? i call shenanigans.
Stunt Rider
I've used Vortex and driven. Both have issues with wear and tear.
Oh wait!!! All sprockets wear and tear over time........ Haha!!!!!!
blasphemy.
UR B-hind Da 8 Ball
13,000 miles on this one. Vortex AL w/ hard anodized coating. Proper chain maintenance and alignment are EVERYTHING! Only reason I ganged it was because the chain was getting a bit funky (some o-rings showing signs of cracks developing, and a couple of very slight kinks that cleaning wasn't solving).
Edit: What looks funny on the top teeth, isn't wear, but grease build-up that I didn't wipe off before the pic.
Woah, woah, woah, woah, woah. So is this something I should change, like, every time I change the oil filter? Because they're right next to each other so makes sense. amirite?
Living The Dream
supersprox /thread
Reads the rulez
:yes
hey man! im new to this forum so bare with me haha. i just got a 520 conversion done yesterday and let me tell you.... its amazing and amazing smooth! so what i did was go with SUNSTAR sprockets. I dropped a tooth in front (15t) and stayed with the same amount of teeth in the rear (45t). The guy i went to gave me much needed info and tried to help me out, so that was an advantage. He recommended a 525 o-ring chain since the conversion may eat up the 520 chain rather quickly. But, i guess the sunstar sprockets needed a 520 chain. So we went with a D.I.D x-ring 520 chain. If you do not know, there are 0-ring, x-ring, and i believe y-ring? chains. Well the o-ring chain is the cheapest and has less cushioning/padding so it will tear up the chain faster. Then its the x-ring chain and that chain is suppose to last longer and it is several bucks more. well, overall i am content with the outcome of the finishing adjustments! I believe i do not need a speedhealer but i can tell the difference. My mph is about 5-10 mph faster but that is ok. Let me know if you have any questions!
Stunt Rider
That's right bub, o-ring, x-ring & w-ring. Make sure to adjust the chain after a few hundred miles. It'll loosen up and stretch a little.
:eek5
Chains STRETCH?!?!?!
Stunt Rider
1 - 20 of 20 Posts
