I got a 01 r6
I had no power to the start button so I bypassed the blue wire to the blue/white wire of the starter relay. Walla I had the motor cranking finally but it wouldn't start.. It's getting gas cuz I tested the pump into a empty bucket.
I check for spark on all coils with plug in the coil and touching the coil on the engine block to ground it and no spark at all.
I have the clutch and kickstand switch bypassed and the kill switch works because it primes the pump.
I also charges the battery till it reached 13.2v off the charger!
The cut off relay clicks when flipping the kill switch idk if that's normal?
It turned on and ran just the other day!
How do I check the pickup coil on right side of motor?
