1 - 4 of 4 Posts
'02 Yamaha R6
Hey guys, I have a 2002 R6 and have been having a ton of trouble try to get the battery to charge while running... Anyways, I have changed the battery, the regulator/rectifier, and the stator and am still getting a little more then 12 volts to the battery with the bike running at 5 grand where it should be reading 14 volts. I checked the power coming from the r/r and it read about 14 volts with the bike running. Is there anything else in line from the battery to the r/r that i havnt checked yet? maybe in the wiring harness? oh, i have also changed the starter relay. I am getting really frustrated with the bike and any help would be much appreciated!
Banned
take a close look at the regulator plug. that was a know issue with those years.
the plug wires would burn up.
guys were making their own connectors with standard blade style connectors straight to the regulator.
'02 Yamaha R6
Discussion Starter #3
Hey blue, I have checked all of the visable wires and plugs... They all look fine, that's why I'm so confused as to why I am losing 2 volts from the regulator/ rectifier to the battery...
Yes I am the Devil, Bobby
check for voltage drops on the positive and negative sides, with a dvom (digital volt/ohm meter) set to volts you should expect 0.1v per connection ( if there are 3 connections in the circut expect .03v maximun loss) hope this helps.
1 - 4 of 4 Posts
