1 - 8 of 8 Posts
Ride it like you stole it
What is stock sprocket size? How many teeth? Anyone have recommendations on what kind to buy?
On yours its 16 / 48. if you look on motomummy.com on the lower left hand corner you will see it. i did the work for you cuz im bored at work.
hope this helps!
Discussion Starter #3 (Edited)
Thanks!!
Any ideas what the difference is on the chains where it says 520 or 530? I'm looking to keep it stock.
Discussion Starter #4
Anyone know the difference on the chains where it says 520 or 530? I'm looking to keep it stock.
the 520 and 530 numbers represent the pitch of the sprockets. Think of it this way a 530 chain is thicker than a 520 chain. So if you were to go with a 520 chain and sprockets then you would have a thinner set up than someone running a 530. Running a 520 reduces the weight of ur chain and sprockets by about 1 pound but that can be pretty significant when you reduce the weight of the moving parts of your bike. Going with a 520 should increase throttle response and if you decided to change you teeth of the sprockets it will give you more accleration or top end whichever you prefer
Discussion Starter #6
What is the pitch of a stock chain?
Discussion Starter #8
1 - 8 of 8 Posts
