1 - 8 of 8 Posts
passion 4 bikes
hi,new to the forum so just want to say hello...iv stripped the threads on my 02 r6 sump so I have got a new oil pan to fit I was just wondering if anyone has changed one before and does it just come off with nothing falling out when removed,i:e can I just remove all the allen key bolts and remove the old one and fit the new one with no problems.many thanks.
Stunt Rider
Yeah!!!! Time for a new oil pan!!!!!
Ow ,NuckenFuts
The thread is 14mm 1.25, get a 14mm 1.5 tap ( $10 ) and a matching bolt ($3) at autozone. Screw the tap in to re thread it and your good to go.
Then get a permanent marker and draw an arrow on it so you don't turn it the wrong way and strip it again.
Yamaha 4 Life
I just did this job recently on my 2010 as the previous owner stripped the oil drain threads.
Was a simple job, and the only thing that "fell out" was the plastic oil drain pickup cover thing (honestly dont know what the name of this part is) and all I had to do was just push it back into place.
As far as RTV, there are differing opinions here. Personally, if I am using a gasket to seal two surfaces and the mating surfaces are perfectly flat with no undulation I see no need for it. I used none when I did the job and after 10 track days this year I have yet to see a drop or even a weep of oil.
1 - 8 of 8 Posts
