1 - 3 of 3 Posts
im trying to dial in my suspension for my fatness (5' 10", 200#). my bike is an 07s model and i currently have the rear preload set to the seventh spot from full soft. does this sound about right for my weight. the factory setting for rear preload is the 4th spot from full soft. the rest of my settings on the front and back are still set to stock. thanks :confused:
You need new springs if you check your static sag at that setting it will be 0mm. Try a 10.5kg rear and a set of 0.95 fronts. The stock rebound on the forks will need a revalve to cope with this as its too fast with stock springs set on max.
MM
1 - 3 of 3 Posts
