1 - 5 of 5 Posts
im buying the extension swingarm pieces i was wondering if anyone else has done this and advice on it. like what size chain i need what it looks like how it holds up if you could let me know
I think the only advice you'll get on this forum for this is "DON'T DO IT!"
Go Ahead
They should be as easy as changing your wheel. Take the wheel off and take the adjusters out and install your new extensions.
It's your bike, do as YOU wish.
-Ant.
Official Noob Greeter
You will need a longer rear brake line, and probably a 140 or 150 link chain depending on your gearing and model. You pretty much take off your old chain, wheel, and adjusters, bolt in extensions, change rear brake line and bleed it, remount wheel, measure and break the chain, and mount chain. You will likely need a lowering link as well or you will be at dirt bike height.:laugh
1 - 5 of 5 Posts
