1 - 4 of 4 Posts
opinins on t-rex spools
who uses these? how do you like em? how tight do the mounting bolts need to be so the spools dont vibrate loose? thanks :confused:
My R6 eats bugs
they are and arnet load bearing. use blue locktite so they dont back out but can still be easily removed. the only time there is weight on them is when its on the stand and if you have your doubts about them snapping off then swap out the hardware with grade 8 pieces
1 - 4 of 4 Posts
