1 - 9 of 9 Posts
so my 99 (carbeurated) r6's fuel light just came on after filling up only 75 miles ago!! before i was getting around 130 (which i still think it should be higher). what's suddenly gone wrong? i put a new midpipe and canister on it back in september but have not got in rejetted or the carbs resynced. i know i need to do this, but only now am i losing milage. i can tell it's running lean because it wants to stall every time i am at a stop light (and people who know more than me told me it was lean). i also checked my tire pressure and it's acutally higher than it should be. last time i filled them they were at 35psi and now they're at almost 45psi (it's about 100 degrees here if that would affect it). SO. any help here?
thanks guys.
hell, mine comes on anywhere from 90-110
75 is a bit low but 130 is freakin high...
As for the psi, i usually run 30 front and rear...not sure why it would suddenly be at 45 for you now. As for mileage...maybe it wasnt a full tank, not sure what could cause it on the carbs. Could also be in need of a tuneup (plugs etc)
no, i have stock plugs and filter (i think the filter is stock... i bought it used though).
but my point is mostly that it was fine before and now it's gotten bad.
also, i agree that it needs a 'tune up' but what does that mean really? take it to the shop and say "tune this up"? i dont want to throw money down the drain and into the stealership's pocket...
hmmm well you say its lean but i would bet its really rich i.e. poor milage maybe you have a stuck float in your carbs plus lean it will run really really hot i remember i melted a pair of fairing once on my gixxer after i bought that poor thing i didn't realize how lean it was till it was too late luckily no engine damage was done
hmm that's possible. she heats up really hot really fast when i stop at lights... but generally not higher than like 210 (on a really hot day). is that average?
MACGYVER 05 R6 NJ
210 is normal. If you dont have the repair records I would try to do a basic tune up sync the carbs, air filter, plugs if they are due.
Replace your air filter and plugs. You might need to replace the spark plug cables too. Also, get your bike tuned and your carbs re-sync'd.
1 - 9 of 9 Posts
