1 - 5 of 5 Posts
Hi, im concerned about the way my bike act after taking out the carbs to do some exterior cleaning and lubrication . The starting is fine but as soon i give it some throttle while moving it bogging on me. Is it carb related issue or anything else?.
Vacuum leak. Double check the intake and airbox boots to all be tight. Knock a screwdriver on the carb bowls in case a foat is stuck
i did that but no progress, still the same. one thing i noticed when i started it is that the 3 way pipe connected to the fuel pump was leaking a bit of gas. after that i decided to disassemble the carbs anyway but honestly they were decently clean from inside.
Did you remove the jets and try cleaning those also
1 - 5 of 5 Posts
