Does the bike die or does it just sit there at idle with no throttle response?
Let me know how it goes. Sounds like you need a battery anyway.Really? And it even fixed the throttle problem? I will go out and try that right now! Thanks!![]()
if this were true you could only ride a few minutes... and always need to either re charge your battery... or buy a new one...im pretty sure riding around wont charge your battery. It will hold the charge but unlike a car it wont re-charge the more you ride. (if that makes any sense)
I understand what a stator is... this isnt my first rodeo here.if this were true you could only ride a few minutes... and always need to either re charge your battery... or buy a new one...
you bike has an "alternator" called a stator, which will charge your battery as you ride.
To the OP, pop the battery out, head to auto-zone and have them do a free load test on it, if the battery checks out, and holds a charge, then your problem sounds like something with the bikes charging system, which you want fixed before you end up blowing fuses and/or frying shit.
To check this, once you have a working battery in there, (should have 12-13 volt with the bike off), you now need to start your bike, and check the voltage at the battery at idle. it should be about the same as with bike off, about 12-13 volt, then rev the engine to ~5000 rpm while in neutral, and hold it steady while once again checking the voltage at the battery. it should now be climbing to atleast like 13.8 volt, no more then like 14.8 volt. If it climbs above that, your voltage regulator rectifier needs to be replaced, if it does not climb, it could either be your stator, or the rectifier, or both.
to check your stator, locate the harness from stator to the voltage regulator rectifier, (3 white wires 1 black 1 red), and check the resistance of the 3 white wires using the service manual.
My bike is much older then yours but i believe it is all the same as far as the chargin system goes.
yeh put the stator thing in there more for the op as he seemed to not know much about his bike yet.I understand what a stator is... this isnt my first rodeo here.
What im saying is if you get a jump and then ride around, your battery will not gain much of a charge enabling it to start up under its own power the next time you want to start it. You will need another jump. Until you recharge the battery or buy a new one
You should invest in a battery tender to charge the depleted battery (and help maintain the battery during long periods of non-use). Battery isn't meant to be charged by the motorcycle's charging system. :flex:It hadn't been used for about a year, so the battery was dead, and I needed to boost it to get her started.
