1 - 5 of 5 Posts
my clutch lever has some play in it and i want to tighten it up, can i just tighten the nut under the lever?
Intermediate Knee Dragger
If you mean vertical play, then you can try tightening the nut. The worst that will happen is it will make the clutch harder to pull in, and you can re-loosen it a bit if that happens.
MACGYVER 05 R6 NJ
You need play in the lever so you dont over streach the cable and snap it. On my 05 I can pull the lever and I have about 1/8 of a gap before I get tension on the clutch.
sorry about that, i was refering to vertical play in it, i think ill tighten it up a bit and see how it feels
MACGYVER 05 R6 NJ
I just checked mine because i never bothered with it and i have between 1/4 to 1/8 inch play. If you tighten it the next time you have to replace the handel it might be a pain to get the new one in. I would order a new lever like a pazzo if you dont want any play and a better feel.
1 - 5 of 5 Posts
