1 - 11 of 11 Posts
I eat YOUR MOM
i coppied this out of an email that someone sent me, some interesting there info here. hopefully this helps!
Tips on pumping gas.
  • Only buy or fill up your car, truck, motorcycle in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role.
  • A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
  • When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3)stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumpi ng on the fast rate, some other liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money.
  • One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
  • Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom. Hope this will help you get the most value for your money.
I eat YOUR MOM
All about the corners
with my f150, I try everything..
if you really want tips, there is some good stuff on the net as far as "Hypermiler Drivers"
These guys really milk everything out of a gallon of gas..
What have you done Dan? I have a F150 that gets crap mileage.
yeah man, ive never seen it...good post
I heart my R6
Even if it was all true, the gas loss from it turning into vapors would be so minimal you wouldnt even ever notice it...When i ride, all im thinking about is how much fun im having, and not that i just lost 5 cents at the pump from some drips turning into vapors haha
Does our bike have a fuel filter like cars? if so than that debunks the part about not filling up when the gas truck is there
goofball royale
The good ol' gas myths... they come out whenever gas prices shoot up. There's not a whole lot you can do except keep your RPMs down.
1 - 11 of 11 Posts
