1 - 4 of 4 Posts
· #1 stunna
I'm about to replace my subframe with a new one (I wrecked my clean 04 R6earlier this month). I want to know if I need to apply a certain amount of torque to the torx bolts when I put in the new subframe. I plan on re-using the old bolts with some blue loctite.
Also, do i need to know any torque #'s for when I replace my left handlebar?
· Super MOD
subframe 34 ft lbs
handle bar front fork 24 ft lbs
handle bar and upper triple 9.4 ft lbs
under triple pinch bolt 17 ft lbs
they have all torque specs in the service manual, u can download a pdf of one on the link below. its doesnt list a service manual for 04's but 03 is the same
http://www.r6messagenet.com/forums/showthread.php?t=44136
· #1 stunna
cool, thanks.
Just how necessary is the proper torque in this case? Essential? or should I just slam em down and loctite?
Cashmoney I read in another post that you replaced your subframe. Did you use a torque wrench?
1 - 4 of 4 Posts
