1 - 7 of 7 Posts
Before I get bashed, disclaimer: im a newbie who just bought an R6 and tracked my bike. I replaced the tires and looking for settings for:
Front calipers and everything front wheel
Rear Axle:
I looked online and could'nt really find an accurate source.
do you know how to properly install a front axle? (most important step)
I use maybe 1/2 what the factory manual says.
On the rear axle I set mine at ~34 ft lbs. Front maybe ~30.
Front axle allens ~18
Front calipers ~25
All my stuff gets wired too, so keep that in mind.
Alot of guys like to flip the rear axle so the nut is on the sprocket side.
Front calipers ~25
Thanks for responding.
Yes everything has been installed and tightened. I just did not have a torque wrench and since I'm tracking this weekend I just wanted to make sure I had the right settings.
AGAIN, THANK YOU!
UR B-hind Da 8 Ball
Do NOT use the torque listed in the manual for the rear sprocket nuts!! 74 lb-ft?!! For a 10mm stud? Should be closer to 25 lb-ft.
This is wrong in all the R6 manuals. And there have been more than a few threads where someone is asking why his sprocket bolts broke when he applied the "correct" torque according to the manual.
"The Dude abides .. "
agree that the manual torque for rear axle is overkill, ya still need a MANUAL .. especially if you plan to do more track days.
1 - 7 of 7 Posts
