1 - 10 of 10 Posts
Knotty Boy
Ridesmart says: "Brake lighting must be disabled by removing fuses, or other methods to prevent activation of the light."
my buddy has a 2012 R6, and is wondering about the fuse thing... if, being a newer bike, it will complicate the electrical system with his ECU.
I need to figure out the same i suppose for my 2007 ZX6R... will the blue painter's tape over it suffice??
Make good choices.
Tape is required regardless so the plastic doesn't shatter all over the race track.
:YEA
Not according to the trackday providers technical requirements listed here: http://www.ridesmart.info/index.php?page=req.bike
You are thinking of glass. Glass needs to be taped.
EDIT: Actually, it says indicator lenses must be taped. At first I assumed they meant turn signals. But I guess you could argue that the brake light is indeed an indicator light.
Knotty Boy
reason why i wanted lights off is like you guys said, so lights wont become sticky from painters tape glue. k, long as it wont screw up his ecu (like unplugging bulbs like u said) should be g2g.
1 - 10 of 10 Posts
