1 - 4 of 4 Posts
about two weeks ago my trans started feeling really notchy and it was tough to get the bike into neutral. it was about time to change my oil so i figured that could have something to do with it. i changed the oil and the problem is still there. if it's in first and i try to go to neutral it has a lot of resistance and then it will just skip right through neutral into second. if it's in second it does the same thing and just skips right through N to first. when im moving it's fine. when i try moving the bike a little bit just to try and get the gears to line up its still tough to get it into neutral
i have no idea what the issue could be. any guesses?
Yep, adjust the clutch cable and lube it too. Definately make sure there isn't too much play in the cable.
1 - 4 of 4 Posts
