1 - 4 of 4 Posts
hello all how do I turn my bike back on went to the service after 5yrs came back thank god and then bike will not turn on change battery and fuel and all I hear when I press the ignition no sound just a click help anyone
I said biiiiiiiitch.....
Check your fuses.
Check your starter relay.
Check the starter motor.
Can you jump it using a car?
Can you bump start it?
Just lean harder...
Put the bike in gear and rock it back and forth. If you are still just getting a click, bypass the starter relay by putting a jumper cable straight to the starter. Don't forget to check the fuse in the starter relay too.
1 - 4 of 4 Posts
