So I am sure you guys are wondering what the hell I am talkin about. Well after hearing all the complaints I have decided to fix the major problem with the 03/04 R6 headlights. What would you say if I told you can you could send me your headlight assembly and the next day I could send you back your headlight assembly with the low beams on the inside and the high beams on the outside??? Yes I said to have the low beam and high beam on the same sides. I am pretty sure I have figured it out, I am in research and development right now. This isnt an easy mod that I can explain like Angel Eyes so this will be done by me only, sorry. It involves drilling of the metal housing and more. But what would be great is it could possibly be direct plug and play, so all you gotta do is be able to take off your fairings, at most having to run a wire back to the battery which is simple. When you turn on your bike, the inside low beams(50w) will come on. When you flip the High beam switch, the outside High Beams will come on as well. Sorry I dont have pics right now, I gotta wait till I make sure it is perfect. I should be finished this weekend. Let me know what you guys think. I could also add on the option of having Angel Eyes inside as well. Also if I can find the correct spray paint colors then I could make the silver rings match your R6.
