1 - 10 of 10 Posts
So I rode it like 3 hours ago and everything was fine. I turn it on just now and sounds very choppy kind of like a Go Kart. Rode it down the road and it remains super choppy until I get going to about 30-45 mph and in 2nd-3rd gear. Then it is back to normal and very smooth until I get back down to slower speeds/gears. When it makes the switch from choppy to smooth in the middle of a gear it feels kind of like there are bubbles and then it feels like a bubble gets popped and then its back to smooth (sounds like that too in my exhaust). Any help is greatly appreciated!
Tried it again and just rode down my street. It feels like its not getting power at all until I get to about 15 mph. Almost feels like im starting from a stop in 2nd or 3rd gear.
Been doing some reading and the most common answer seems to be a valve adjustment is needed? Does that sound right to anyone else? Some people said bad fuel, but I don't think that would be the problem. Thanks!
I said biiiiiiiitch.....
Are your valves due for adjusting?
When was the last time you had new plugs?
I had a problem last year where my plugs had about 10k km on them and were getting bad (and valves were almost due). It felt a lot like what you're describing. It wasn't consistently firing on all cylinders so it would jerk, and pull, and sound rough at low speed/rpm. Once I would get it up in the revs it seemed to get better.
I dropped in new plugs and it was night and day difference.
I brought it to the shop and talked to them. They said they think its what you said, the spark plugs and/or valves. They are going to run a diagnostic on it and let me know for sure. I'll relay the outcome to you guys just in case anyone cares.
1 - 10 of 10 Posts
