1 - 3 of 3 Posts
Hello, I could use some help or advice from Facebook to networking to YouTube to here.
I have an 2018 R6 14k miles. Spark plugs are good, battery is new. Fuel pump works fine.
problem: at cold start up, my bike turnsover perfectly fine and runs in idle, however the idle is very low andit even sounds weak the first few mins. I’ve noticed it’ll even die sometime. The funny things is the pattern is always the same when I start it it’ll give me problems up until it reaches 130 degrees or so it run and continue to warm up and restart fine if I shut it off.. here a video Of my kinda of problem.. I’ve been told it could need an ecu flash because of my added mods or may need a valve adjustment. I have an after market dry air filter and a cat delete with aftermarket slip on and servo delete. Ideas?
1 - 3 of 3 Posts
