From the makers of the original fender eliminator kit, Competition Werkes brings you the Werkes USA GP Exhaust. Fabricated entirely from CNC-cut corrosion-resistant 304 stainless steel and precision welded, the Werkes GP exhaust looks like no other slip-on muffler on the market. A tapered internal baffle is designed to be lighter than OEM with improved performance thanks to a greater capacity for exhaust gases to efficiently pass through. On some applications, Werkes slip-ons use connecting tubing that is welded together, not bent to shape – giving it the look of a one-off factory exhaust.
We have these exhausts available to fit the following Yamaha R6 models:
2003-2009 YZF-R6/s
2006-2012 YZF-R6v
Werkes USA GP slip-on exhausts are not available on our website yet. To order yours, call Brad at 866.931.6644 ext 810. You may also email us with any questions you have, send those to FORUM at RIDERSDISCOUNT dot COM with WERKES GP R6 SLIP-ON in the subject line and please be sure to include the model/year of your motorcycle and we’ll get back to you right away.
All hardware, clear instructions and even a pair of stickers are included with each slip-on exhaust kit.
Weld seams are flawlessly rendered on each of these mufflers.
Unlike some manufacturers that choose to spot-weld the perforated internal baffle, Werkes USA runs a bead along its entire length.
Much smaller than the OEM muffler, 2003-2010 YZF-R6 and R6s models do not require the use of a passenger peg to hold the Werkes GP muffler in place.
Yamaha YZF-R6v slip-on exhaust from Werkes.
2003-2009 YZF-R6/s
2006-2012 YZF-R6v
