1 - 9 of 9 Posts
is that the left clipon ? .... looks like it... I'm guessing horn..... since thats the ooonly electrical thing on the left side of the bar..... Could be wrong. :poke
Easy to see if its the horn. Pull one off and try the horn. If it dont work pull both of and short the 2. If the horn goes off its the horn switch.
Not sure, but I believe it's for when you have your bike in gear, you have to pull the clutch to start {activating the switch)
Its a switch for when you start the bike up in gear.dont worry if youve got the connections the wrong way round.it doesnt matter.its only an on/off switch.
It senses whether the clutch is in or not, pull the clutch in and you will see the little "peg" so yes it pretty much is a switch..
1 - 9 of 9 Posts
