1 - 16 of 16 Posts
I think i might have the wheelie down and i ordered a new sprocket (15 tooth). How do you position for a wheelie? Then the dreaded endo, how do you get ready for that all together?
wheelie:
second gear
45-60mph
squeeze the tank with your knees
make sure you are nice and stable
pull in the clutch quickly
whack open the throttle quickly and let loose the clutch...quickly
when it comes up (it will come up fast) let off th throttle A LITTLE BIT
as you get better try "dancing" with it to keep it up.
endo
25-40 mph
lock your elbows
pull in the clutch
squeeze the break
lean forward
apply pressure smoothly but firmly and quickly
the back end will start to feel light
squeeze it more and the rear wheel will lift
as soon as the rear wheel lifts off the ground you can let off the break just a little
if you let off too much though, it will drop
DON'T DO ENDOS!!!
(That's how I crashed)
:cuss
penfold said:
Ya, Jas is good at doing 1 o'clock stoppies!
it was more lik 12:45
Ya as far as the stoppies go.....bout 25mph......clutch in.....grab the front brake PROGRESSIVELY...but quickly...ya wanna give teh front end time to compress before you bring in the heavy braking. Just start slow and do slow stoppies then move up. Id post oneof me up here but I have no way of linking it.
As far as that second gear wheelie goes.. IS THAT WITH A STOCK R6?? MAN WHAT THE HELL IS MY PROBLEM.. i cant get my bike up in second gear and everybody on this site makes it sound so easy..
IS IT POSSIBLE TO DO A SITTING SECOND GEAR WHEELIE ON A STOCK 04' R6..
i've found that when i do stoppies i push down on the front end as i pull in the brake, it's just like a wheelie in that there is a balance point and the sooner you get to that point the more you can mess with the brake to keep your ass end up in the air.....i can roll them out for about 30-40 ft this way.....you just have to mess around with them and see what works best for you.....i ALWAYS check my brakes a couple of times before i throw the back end up....and as for wheelies.....2nd gear, throttle in and a nice big WHACK to the throttle right before you let the clutch out.....
there's wheelie threads all over this forum so check them out.....
Short answer, Yes.
personally i don't see the point in doing stoppies, i only wheelie when i'm really hammering it through the gears and it comes up on me, but i have no problems getting mine up in 1st, 2nd, and actually got it up in third one day just goofing off.
I'd much rather drag a knee or elbow than wheelie or indo
personally I don't clutch, I mostly just bounce it up except 12, up but if you're trying to do stand up's it pretty easy. 3rd gear front peg about 70-75ish anbounce and give it gas. it depends on what year it is though my 00 would bearly come up in second but the 03 will come up in 4th so de gentle with it
ive been tryin a stand-up in second (w/o clutch) and can't seem to get the timing right...i got 1st down pat, just gotta keep it there lol...im not gonna try third until i get second down (04 6)
oh i know, thats part of the reason i haven't tried wheelies unitl now (a year after i got bike) i also don't try that many times consecutivly (3-5) the way i see it if it doesn't want to come up im not gonna force it, i just wish it were easier lol
1 - 16 of 16 Posts
