1 - 20 of 39 Posts
RESPECT
So I'm making a list of maintenance as well as upgrades that I'm wanting to do to the girls this winter. Does anyone else write out a list? If so...what's on your guys' lists? It's always better to see more than one list that way if I forgot something. I'm curious to see what everyone else is doing to their bikes to enhance performance, appearance, as well as maintenance.
Speedy Claxton
brake lines and pads, block offs, pcv and autotune, speedodrd and id love to work on some projectors.. good thing i have a good 5-6 months of storage time haha
I definitely do this haha...you're not alone!
My R6 eats you.
Might actually enjoy this winter since it's time for some serious upgrades.
Ohlins 25mm fork kit
Racetech internals for the rear shock
DID ERV3 520 chain
Driven alum rear/steel front sprockets
Woodcraft tire warmers
Woodcraft clipons
Also will be pulling the engine and will be replacing what ever looks worn out.
Ridn' Drty
To many wishlist items but definite items are a -1/+2 set up with a new chain, speedoDRD, and pirelli corsa III's to start off the new season. Buying a house in a couple weeks so the bike items are on the backburner for now. If the opportunity arises then a PCIII, smog block offs, possibly a mid pipe or MJS header set-up. All those will be one big install so one they may be a compilation of buys before the install happens.
RESPECT
I know how you feel. I might be moving at the beginning of the riding season and have to start saving up for that. I want to get most of the basic maintenance out of the way and then to try and do some upgrades to them to get them all prettied up.
AFM #327
DID ERV3 520 chain
Woodcraft clipons
Now thats a good list ^^^
I just wanna get mine running to get it inspected and re-titled for the street in the spring or sold as a trackbike.
Just another r6'er
Headlight mod
Rizoma Rearsets
Rizoma Race Pegs
Rizoma CF heel plates
Rizoma Oil cap
Gear indicator (intergrated)
Powder coating
m5 tires
BMC air Filter
ASV levers
block off plates
dynojet esrm
frame plugs
Angled valves
New spark plugs
PCV and auto tune
then for summer new clip ons, and some carbon fiber (tank sides, rear hugger maybe or match paint it white, can't decide).
That's all so far
NCSportbikes.com
Frame plugs
Get my fairing stay welded back together
Fix my headlight tabs
HIDs
520 and new sprockets
Case covers
Maybe some vinyl wraps for the mid fairings and tank cover
Double bubble wind screen
Brake lines and pads
Get the dent in my tank hammered out
More as the winter goes along but this is a starting point... I'll also be riding all winter so this is just as I have the time and money for the upgrades...
Hakuna Matata, btches!
PCIII,
Speedo Healer V4
07 R6 Speedo
Vortex Base and Cap
FDB Short Levers
No-Cut Sliders
Mirror Block-Offs
Motomummy Res Sock
AggRacing Smog Plates
led flushmounts
Driven Sprocket Nuts
Driven D3 grips
Vortex Clip-ons
D2Moto Fender Eliminator
Billet bar ends
Driven -1,+1
Factory Pro Velocity Stacks
HIDs
BMC Air filter
Red 520 Chain
Hyperpro Damper
and a custom tune
my to do list
slow guy
DID ERV3 520 chain
Woodcraft clipons
Are you going to pull the head and inspect internals? I could see that getting pricey...sweet list none the less.
My list
Install Fren Tubo Carbon lines
Fresh Brake fluid
Race glass
Continue rewiring the bike to eliminate unneeded circuits
Repair Bazzaz speedo plug, install map flip switch
New tires
Go sledding with my daughter when the snow flies:fact
RESPECT
So far all that I know that is done to the bike is Frame and spool sliders, fender eliminator, flush turn signals, HID headlights, K&N air filter...that's all I really remember. I think the first diy mod I'll do is def black out the front wind screen
Bazzaz Z-FI
Bazzaz Z-AFM
Infinity projectors w/8000K HID's
520 conversion -1/+2
Powdercoat-shock spring, brake calipers and other bits
Paint matching wheels
Mirror block-offs
That's what I have planned for now.
ahhh the winter reset botton.
- Repack steering head, swingarm pivot, and lower linkage
- Replace dented swingarm
- Pull engine, YEC head gasket, sprockets, manual chain tensioner, blueprint
- New tune
- Replace calipers (easier than rebuilding when you have a fresh set lyin' around ;))
- Other routine maintenance like chain, brakes, cleaning, etc.
- Finish all body repairs
- New grips
Forks and shock have a fresh rebuild, otherwise they'd both be pulled and redone. Fresher is faster baby!
-penske triple install
-ohlins internals, gp suspension compression valving
-new chain and 15,16,45,46,48 sprockets
-case covers
-Disassemble head, R&R and inspect/prep valves, check valve spring pressures, angle mill, and maybe serdi valve seat resurface, slotted cams
-new gaskets, basic winter maintenance
-buy extra front wheel
-stocking up on extra rearset pieces, clipon bars, and of course tires.
out of the budget, would be nice.
My R6 eats you.
I may have to, it's not running right at all. I'm buying most of my stuff used suuuuper cheap, probably under 1500 for everything I listed.
WIN-TER? Whats that?
Haha
All I got really planned out between the rainy days are replacing the fluids.
Installing my T Tuner (when I get it)
New Airfilter
I know Im missing some others but thats what is on there now.
1 - 20 of 39 Posts
